PVC window can open but pins catch on closing
21 Feb 2021
This has happened before. Was working alright but in either extreme heat or extreme cold cant shut it (kitchen window.)
I have to swivel the handle to move the pins around to get it to close.
What causes this? How can I fix it?
Just checking in again this seems to be a problem for a fair few.
Yes, the side hinges have an adjustable positioning, just a matter of setting each side so it doesn't catch on the sides, or top/bottom.
Thanks, I'm assuming if the pins are catching i..e like the window has been lowered then I need to loosen the screws , push the window up and tighten?
My other question is won't it just naturally adjust when the extreme hot weather goes?
you need to know what the problem is.
what are the mushrooms hitting on -the edge of the keep or the edge of the window?
your first thing to do is go outside and see if the window sash (thats the opening part with the glass) has an equal overlap around the frame.
is it top hung or side hung?
sometime the sash rail sags a bit, sometimes the friction stays move a bit and one side drops
maybe the glass wasnt shimmed properly allowing the sash to go out of square
just a bit if info -the friction stays usually have one or two holes that are slotted -allowing adjustment, then there are a couple more which are just holes and have no adjustment. When fitting initially, the screws in the slots are put in first, window is adjusted until equal gap, then the others are put in to secure position. However the screws bite into plastic and ca work a bit loose.
it's top hung so it's now lowered and the mushrooms are now catching like in the Youtube video I posted.
