Having some issues with my pyronix alarm. It has been recently serviced with brand new batteries throughout. I’ve tried to ask the alarm company about this but they want another call out charge to attend and I cannot afford it, especially given the expensive service recently.
Problems:
1) sometimes my Wi-fi cuts out or I have to reset it eg if it’s not working properly. Whenever I do this, my alarm box will beep at me a couple of minutes later with a fault signal telling me it has no Wi-fi signal. If I ignore it, it will beep at me in the middle of the night.
2) the alarm company talked me thru in the phone ….went into the engineer mode and then entered Wi-fi user ID and password. Alert on the box turned off and it is a happy box again.
3) however ever since then my alarm keypad will chirp every single time I open my front door, even if the alarm is off and we are just going outside to get the milk!
4) when I set it, it no longer gives me an intermittent beep and then a chirp….instead it is one long continuous beep and then a chirp.
5) night time set…no longer works properly….I can wander about my hallway (where front door is) without the alarm doing anything. So it’s not working properly.
Help, please! It seems to have gone into some setting that is different than before.
I do have two Wi-fi systems (one the hub and one is a mesh system that boosts it). Would the alarm be behaving like this if I changed from one wi if system to another? That’s the only thing I can think of that might have changed.
Problems:
