- Joined
- 13 Jan 2019
- Messages
- 6
- Reaction score
- 0
- Country
Hello All,
I'm a new member to this forum, so please excuse me if I don't follow accepted practice for some reason (and let me know how to do better in future!) I have been searching around this forum (and more widely) to a solution to a recent problem, but to no avail. I'll try to explain as clearly as possible...
We have a Pyronix Enforcer alarm system installed in our house, which has been working well for around nine months. We have a fairly simple/standard domestic setup, but recently found a problem in that on entry to the house with the alarm set, the entry timer is not started by the door sensor, so that the hallway sensor then picks up motion and sets the alarm off.
The magnetic door sensor is a wireless Pyronix MC1MINI-WE two-way wireless magnetic contact switch. I have run the engineering diagnostics on the control panel and I am pretty sure that I have found that this is where the fault is, but I don’t know what to try next. The magnetic front door sensor shows full battery strength (lights show on the door contact itself as well) and full signal strength (as do all the sensors in the house), but when I open the front door the diagnostics mode shows that the input status remains at "C" (closed) and does not move to "O" (open); in other words, it does not appear to detect the door opening and therefore start the entry timer running, which then means that the PIR sensor in the hallway detects our entry first and triggers a full alarm condition. All the PIR motion sensors correctly flick from "C" to "O" as expected when they detect motion and viewed in this diagnostics mode, so it does seem to me just that magnetic contact switch that is not behaving properly.
Clearly, there is a workaround (to use the a fob to disarm before entering) but some people who enter our house legitimately don't have a key fob and I would like to get this working properly again.
Can anyone please suggest what the underlying fault may be and how to proceed further in investigating this problem?
Many thanks,
Andy.
Many thanks,
Andy.
