Pyronix Enforcer fault
5 Feb 2017
I am tried to install a Pyronix Enforcer. My electrician has done the following:
The main power from the house consumer unit is using a 10amp fuse circuit and that goes into a spur switch which is then wired into the Enforcer. When I switch on the spur switch to power up the Enforcer the relay trips from consumer unit every time.
Is the Enforcer faulty. Maybe the psu or have we wired the Enforcer on the wrong fuse rating. What could be wrong. My elecrtictiam told me he thinks the Enforcer is faulty and I should change it.
Any ideas what's wrong here?
Get some flex and a plug & plug it in to a wall socket. If it trips your ring main then it’s the panel. If not it’s a wiring fault on the spur or consumer unit.
I have just tried flex cable and plug into wall socket. It powered up ok and did not trip relay. So the the error is probable with the wired in the spur or consumer board.
Has he made the stupid mistake of putting the neutral on the wrong side of a split load consumer unit ? If you have one ?
