Pyronix Enforcer - Finding a fault / Missing nut in sensor
9 Oct 2009
Bristol
Hi All,
I have just moved into a new property that has a wireless pyronix enforcer alarm.
Now the first issue, I can't engage the alarm
1) It says 30 - Car "tamper on input" . So it seems this is either a loose case or a faulty battery, I naturally went into the garage and found a contact sensor on the garage, removed the screw and it triggered the control panel to beep but that came up as "20 - Garage". Is there anyway to find out what this is, apart from opening every sensor?
2) Open opening the contact sensor in the garage, when I put the lid back on, the screw was loose. Seemingly, there was either a missing nut or it fell out when I removed the cover. I suspect these are pretty generic but any tips on where to get one, rather than skulking around B&Q for one.
3) Finally I would like to see if I have "admin" passwords, any standard ones to try, I think I have seen 1111, 1664 , any more?
It is about 14 months old, and that must be what it is...nothing else makes much sense. I will message the sellers and see if that is the case.
