I will be replacing an old grade1 DIY wireless system in my 3bed semi with something more reliable, and importantly, something I can control with my phone remotely.
After much research, I think Pyronix Enforcer V10 with HomeControl+ seems to be the best grade2 wireless system for remote control - would you agree?
I have not yet decided if I'll self-install or have someone do it. I assume that won't be too hard to self-install, as this is a wireless system and I'm good with manuals.
So, I am assembling a parts list and I have the following questions (so far):
- I am thinking that ADSL/WiFI is not very reliable - mr Burglar could just cut the virgin media optic cable outside the house in my porch and then get it. For this reason I think I'll go for DIGI-GPRS and get a sim card. Note: I don't have a home phone line at all, so pstn wouldn't work. Questions:
- Any suggestions on SIM?
- Will I still be able to use wifi as a backup? ( I suppose not)
- How much data would this setup use per month?
- Any way I can get the V10 panel with DIGI-GPRS instead of DIGI-WIFI which seems to be the default? Throwing away the wifi card seems like a waste.
- The current grade1 panel is fixed on the hallway just by the entrance door. I could fix the Pyronix system there I suppose, dimensions are similar. Wouldn't look great, but are there other disadvantages? Should I finding another place to fix it at? E.g. inside a kitchen/utility cupboard or under the stairs near the electricity panel? Does it matter if the panel is near, for example, the microwave oven?
If I locate the panel further into the house, I'll probably also have to get a remote keypad, an extra cost. I currently don't plan to use keyfobs or proximity tags, so the system will be operated using the phone mostly, or, if phone battery is dead, from the keypad.
- What is your opinion on the Pyronix magnetic + shock sensors (MC1/SHOCK-WE)? I'm thinking of getting 4 of these to cover the front bay window, the dinning room patio doors and the kitchen door and window. The entrance door will be covered with a magnetic contact (MC1MINI-WE) - not sure if a shock sensor is needed there.
- Most of the rooms (entrance hallway, lounge, kitchen, 1st floor landing) will also be covered by a PIR - currently considering whether to go for KX12DQ-WE or KX12DT-WE (these also do microwave). Any thoughts on whether microwave is worth an extra £15 per sensor?
