I have a Pyronix Enforcer system installed in my flat.
Recently I have had a few faults come up, mostly about low batteries, and that’s fine, I can set about getting the batteries changed.
My problem is that when those alerts come up, it causes a repetitive double beep from my control panel which is responded to by a double beep somewhere else in my flat and it is SO LOUD. I then desperately spring to the control panel to silence the alarm but eventually it will go off again (this last time was at 2am this morning and I’ve not managed to go to sleep since, hence this post!)
I appreciated the solution to this is to replace the battery but in the meantime, does anyone know if there any way to either:
1) silence these fault alarms completely so all I get is the amber flashing light and no associated deafening noises? OR
2) reduce the volume of these beeps so every single flat in the building doesn’t have to know about my low Siren 1 battery...
Thanks!
Thanks!
