pyronix enforcer wifi
18 Nov 2017
i have put a wifi module in but there is no comunications bit in menu to set it up
can anyone help
Power the system down (inc battery) and power back up. Coms mod must be added before power up.
hi there
thank you tried this but still no comunications
but thanks for your help
hi thanks but there is no menu that says communications so cant get to it
just found out that when i power down and start up again it should be mains first which i did not do but if i power down the system and unplug battery will i lose all my settings and detectors that i have inputted etc
so powered system down unplugged battery and then powered back up mains first but still no communications menu or set up app menu
can anyone help please
First off you need to make sure that you have a firmware software that supports the app. If its a older enforcer panel I don't think it will recognize the wifi module.
You can find this out by going into engineers and going to software revision.
