Pyronix full set problem
16 Feb 2020
Hi
I have set up enforcer with 6 pir and 2 door contacts.
Pir at upstairs is zone A
Everything downstairs is zone a+b
Main door is set 07 final exit (fx)
Pir in hall is 09 Er (prt fx)
Rest all 06 intruder
If I set with key fob zone b works fine
But if I do full set with key fob from outside my how with main door closed, after initial countdown alarm sets off
But if I set with open door and then close front door works fine
Do I have wrong setting for front door contact? Which is 07 final exit
Hi
Thanks, now if I set b zone and walk downstairs pir in hall gives me enough time to enter code in panel, but if I am coming back from main door with full set , when I open main door nothing happens but sooner I pass hall pir which is set to 09 Er (fx) triggers the alarm. Help please
If I open the door press lock button on key fob then close the door, alarm set ok no problem
But if I lock the front door and try to full set alarm , then it’s fail to set
Message on control panel reads ; alarm set failed.
I think it’s mc 1
Hi
Are these any good
That’s better
Are you sure that it’s set as 07 final exit ? And what is area A set as in setting type ?
Hi sparkymarka
Thanks for help
Just managed to sort the problem
Had to change settings in system options , exit modes and select option 2 timed/final
Now I can set alarm with key fob from outside the house with main door closed
Or can key the code and walk through the main door. Thanks for help
