Pyronixs enforcer entry 08 trigger
15 Jan 2017
afternoon !.
I am installing a fourth pyronixs enforcer for my daughter.
I have successfully installed three others, having trouble with this one.
I have fitted a door entry sensor, it's learnt and configured as 08 Entry route.
However, each time the door is opened on full set A, it triggers a full alarm?.
Any suggestions welcome please as I intend to fit another at our holiday home !.
Trev
I believe I have mine setup as
the front door is final exit and sensors that detect you between the front door and the alarm keypad should be entry route not the door itself.
I am not sure the numbers but it seems to work as expected. I am sure others can give you all the options.
Program Hall PIR as ER area FX think its 06. Hall will then be omitted during entry/exit on A and will start enrty timer on B in the morning. Front Door should always be Final Exit and in Exit modes make A as Final Door B as Timed.
