Im in the process of installing the Enforcer V10.
Everything is done apart from the bellbox, before I connected it I wanted to test the system alarms when it should and that the sensors are set up correctly. But I cannot get the alarm to trigger!
When I set A the exit timer is started, I open and close the front door, panel makes a chime noise but then when I reopen the door the entry timer is not started and waving in front of the lounge or kitchen PIRs does not trigger the alarm.
Similarly if I set B, go upstairs for 5 mins then come back down, none of the PIRs or contacts triggers the alarm.
I've checked the panel log, no entry of alarm being triggered. The HC+ app shows the area as set but no alarm sounds/ shown on app.
All sensors are connected, plenty of signal strength etc.
Any ideas?
Any ideas?
