questio answer
7 Mar 2007
Cambridge
A friend of mine attended an interview to be a sparky at a factory, one of the questions he was asked was the following:
Whats the difference between a Delta and star wound motor and what are the applications for the use of these 2 motors?
My friend Frooze and didnt get the job.
Some motors can have a supply voltage of 11,000volts
That, of course, will be three phase.
Depends on the application. For example, some railway systems use a single phase AC voltage of 25,000V, 50 Hz.
markymark2406 said:
so can star/delta motors be in 240 or 400 volts?
Talking bog standard 400v 3 phase supply:
With Delta each winding of the motor is connected across 2 phases and has 400v across it.
With Star each winding of the motor is connected from a phase to the star point. The result of this is each winding having 230v across it.
Used to work with 230v 3 phase motors, transformer stepped down
They may well have been although not certain, they were fitted inside a "Heron" camera crane, Vinten who made the crane were/still are, a british company, the motor drove a hydraulic pump which in turn pressurised a reservoir which in turn drove a hydraulic motor.
