Question re cutting large rough surface floor tiles
28 Nov 2010
Edinburgh
Hi
A question please, I have tiled splashbacks and done some bathroom wall areas but always with smooth ceramic tiles
I will be tiling a kitchen floor soon and using large (probably) ceramic floor tiles. They look a bit like slate and have a rough surface.
I have a large vitrex tile cutter, think it's 800mm long I usually use for my clean cuts. Will this type tile cutter cut the above tiles with a rough top surface? Quite a thick tile too. My tile cutter I refer to is the sliding small wheel down the tile and press handle to crack, standard tile cutter!
It should, in theory, do so. Might be worth testing this on a tile prior to the job but you will probably need to get a new wheel. If that still doesn't work then buying a cheap electric cutter might be easier than struggling with an angle grinder. They cost around £40 for a basic one.
