Quick Question For A Plasterer
5 Nov 2008
Hi
The old plaster in the revel above my window is blow and I have tapped it all down, not all you can see is the concrete lintel.
Can the lintel be directly PVA and skimmed or would it need a small coat of bonding first?
Many Thanks
OK can it be a thin coat? about 5 mil - then skim on top of that?
Window vents are close to the top otherwise.
You would normally plaster it back to the same thickness that was on before.
Roughcaster.
:idea: next time you face this situation ask the window manufacturer to fix, or allow for a knock-on to be fixed to the top of the window. :idea:
