Hi all,
I need to replace the combi boiler in my bedroom (can’t relocate it) and want the quietest option. I’ll build an acoustic cabinet, but I’d like to start with the best baseline.
I'm looking for around 25-35kW with hot water flow rate being an argument to go higher, but I could see demand being below 3kW/h often so maybe that's an argument to go lower?
I've seen conflicting info:
- Viessmann Vitodens 200-W: Sometimes listed as 36 dB, but the ErP label says 48 dB. One manual shows 32–33 dB at partial load, but there's no indication of what partial load actually means.
- Viessmann Vitodens 100-W: Generally said to be louder than the 200-W, but the ErP figures are almost identical. The manual listing partial load puts it basically the same as the 200-W.
- Worcester Bosch Greenstar 2000 (and 4000): I’ve seen ErP sound power of 43 dB in some places, 47 dB in others. Is the 2000 actually quieter than the 4000?
- Vaillant ecoTEC plus → Seems like another contender, but I can't find much beyond the ErP sound power and QuietMark.
From what I understand, ErP = close to max noise. Does anyone know how these models compare at lower loads, and what sort of “real-world” average noise I might expect? Are the differences between the models actually noticeable in day-to-day use?
I’m in a 2-bed flat, ~5–6 kW/h demand on cold days, so most of the time it’ll run at low output. Hot water noise is less of a concern.
If anyone has experience with these models (or better data sources), or other recommendations, I’d really appreciate your thoughts.
Thanks!
Thanks!
