- Joined
- 7 Jan 2010
- Messages
- 14,258
- Reaction score
- 4,288
- Country
I'm lost, how many questions are on the go, and which one is the one to be answered ?
Correct.
Crystal s QI'm lost, how many questions are on the go, and which one is the one to be answered ?
Is it a common rail diesel injection? If do, you shouldn’t drive it but drain it. Although I did put a quids worth in my Evoque and then brimmed it."Bodd, post: 4911348, member: 124671"]
Just put under £5 of unleaded in my diesel van.
I had just put some Redex in as well before. Then I filled the tank up with diesel...
What do you think Mottie
Yes, for the Syria question. Sunbeam Alpine was the correct answer for the Bond question that you put on hold.You said it was a Hamster
It's vauxhall movano 2014.Is it a common rail diesel injection? If do, you shouldn’t drive it but drain it. Although I did put a quids worth in my Evoque and then brimmed it.
NopeIn a desert
Well, you’re not supposed to but I’d probably take a chance if it was mine but keep it topped up with diesel as often as you can.
Yeah, it will act as a lubricant. The reason you’re not supposed to put petrol in is that diesel lubricates the high pressure fuel pump and injectors. Petrol dilutes it.I'm going to do that it was less than £5. Should I put the rest of the Redex in?
Were you distracted when filling up then? Thinking about how well your quiz was doing?![]()
South Americawhere would you find the Altiplano?
Yes but more detail neededSouth America
AndesYes but more detail needed
