- Joined
- 30 May 2024
- Messages
- 8,049
- Reaction score
- 3,131
- Country
30 miles at best150 miles?!
Done away with them now but they are using a wet belt on some engines to drive the oil pump.Fair do's looks like I was wrong, thought all the new Fords were wet belts.
There you go with your bigoted nastiesm.White van man rides again.
Yeeehaaaw!
Don't be posh. Those Hub caps are 16" Alloys.Those hub caps and the rest of it
Ford is no Enzo Ferrari
You posting this, just encourages my Fannyism
I didn't notice that you were indecisive, my advice is to buy whatever your gut feeling tells you. Bare in mind that whatever you buy only has to last you 10 yrs at best unless you are planning on keeping it beyond 70. Anything reasonably new should easily do that, I would simply look at the cheapest option for a work horse, the cheaper the outlay the more proffit is left in your jobs for you.You posting this, just encourages my Fannyism
Im so temped. Im also 60 next month.
Im getting more and more indecisive.
Im shocking.I didn't notice that you were indecisive,
I think ill stick with the White. Its a nice looking van but it will also be my only vehicle for a while. So I might Jazz it up a bitmy advice is to buy whatever your gut feeling tells you. Bare in mind that whatever you buy only has to last you 10 yrs at best unless you are planning on keeping it beyond 70. Anything reasonably new should easily do that, I would simply look at the cheapest option for a work horse, the cheaper the outlay the more proffit is left in your jobs for you.
The 'Atkinson' engine Ford use is not a true Atkinson engine, more an Atkinson style engine. Look up a true Atkinson engine design and it’s pretty weird (and huge) with all rods and levers but Ford mimic the principal while using a traditional crank/rod/piston design. I think some other hybrid vehicle manufacturers use the same engine or at least, the same principal.
I will say the 17" or 18" in black would round it off a bit.
Never been into tarting up a scone, but they would make it look better.
You could get some nice Reform stickers to jazz it up a bit, the blue really goes well with white.Im shocking.
