Hi all,
In new builds do radiators need to be designed to meet the requirements of the room size and kw output needs?
Reason being, in a friends new build the radiators are tiny and blatantly undersized; probably half the size need and rooms do not get warm due to this issue.
The builder is proving to be a constant nightmare and refusing to answer concerns with this and many more issues with the new build. It seems builders can do as they please with no governing body in place to help sort out complaints.
Basically, does the installer need to comply with any regulations I could use to get them come back and alter the system.
It seems plumbers worked to a plan and installed the rads then a gas fitter later came and installed the gas boiler and commisioned the system.
Many thanks in advance
