Age old problem of one cold rad in a house again. Would be grateful if I could pick the brains of you experts out there.
Some background. I have an oil fired boiler and a stanley stove as back up. Recently done some work done at home on oil fired heating as it had been sucking in air. The pump had been sending water up the cold feed to F&E tank causing the tank to overflow and the radiators to start emptying. so the cold feed was reposition before to the pump which is on the return just prior to boiler. My heating all now appears to be working properly but I cannot for the life of me get heating to one radiator upstairs. I have tried closing all other radiators but this did not seem to make any difference. I drained down and changed the valves as I suspected that could be the fault but to no avail. There was an issue when it came to draining down in that the F&E tank failed to empty so clearly there was some kind of airlock. To rectify this I backfilled the system through the mains and all radiators filled this way.
I used the stove last night and the radiator in question
heated up fine but when using the boiler again this morning this rad was again stone cold. I turned the pump up to 3 hoping that this would clear the problem but all this did was cause the system to vent into the f&e tank.
Could somebody please explain how I can get this one radiator to work using my oil fired boiler
