I have a small but a constant drip form the bottom of 1 of my radiators downstairs. The others are OK. Tis drip started today and must be due to rust from old age?
I want to replace the radiator without draining down my whole heating system.
Do I need a radiator exactly the same size as my current one. It is single panel type?
Also, to replace do I use the same brackets or need to use the new ones with the new radiator??
Thank you for your help.
