Hello just wanted to confirm that if you're not using Thermo Rad Valves or using Thermo Rad Valves which don't need to be on a certain side then it doesn't matter which side the flow and return are connected does it and the valves on each side are the same aren't they?
Thank you very much
Thank you very much
