Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Don't need to tell you anything, the OP does. Read what I've said Softus. Don't start off 2009 the same as you finished '08. If people choose not to follow your advise to the letter, then, as I said, GOOD LUCK TO THEM.
I did. The gist of what you "said" was to wish the OP good luck.
However, luck doesn't come into it. Leaks aren't fixed, or obviated, on a wing and prayer. The point you're missing is that he couldn't possibly have fixed a leak by putting PTFE on the threads. Either you don't understand that, or you're being deliberately obtuse
crikey, i didnt mean to cause all this tension, i think it might have been that when i undid the nut i reseated the olive joint aswell and maybe put more torque on the nut, anyhow the leak is currently gone, i have had tissue paper next to the join for 2 days and had heating on and off and there has been no drips.
thanx all for your help hope everyone can be pals again!
I have no doubt that this is what happened, however there are two reasons for putting PTFE tape on the wet side...
1. The tape goes where it will assist in making a seal, instead of where it will interfere with doing up the capnut.
2. In applying the tape you get to check that the olive is onto the pipe as far as it should go, and that's been lightly crimped so that it can never fall off.
And in case you think that olives never fall off, it happened to me the other day on a pressurised system that had been installed by a nameless British gas and heating installation company. I turned the TRV head to raise the temperature, and hot water started geysering out at 2 bar.
