Radiator near thermostat
3 Jan 2015
London
I have read that the radiators in room of thermostat should not be fitted with TRV's.
If retrofitting a wireless thermostat in a room where there is a TRV or of out was fitted in error would it help to set them on Max or do they need to be removed?
Thanks all. So which one is it?
If setting to max does the job then I'd rather do that. Is this correct?
Remove the head.
You could loosen the head so that it wasn't acting on the pin but still looked aesthetically pleasing
Yes.
Setting to max would provide a room temperature of about 26-28°C -if the rads were large enough. The TRV will be fully open if the temperature is more than 2°C below that. For a typical room thermostat setting of 20-21°C the TRV will therefore be fully open - same as if the head was removed.
Not only do they look silly without the head but the sticking out pin is a hazard to very young kids!
What TRV do you have?
I have same scenario with a Myson TRV. Myson TRVs have two metal tabs around the underside of the head that can be moved and slotted in to set the head between to tolerances. I set the min tab to the max so the head can't be moved at all.
