Radiator not bleeding
4 Dec 2011
Glasgow
I know this topic is years old but thought I would post anyway as this is one of the first websites that pop up when you google radiator wont bleed.
I did what paul the plumber said and my radiator that was heating only halfway sorted itself in no time.
23 Jan 2012
Florida
OK, I know this is an old thread, but I was looking for an answer I could not find...
due to high costs of heating in Europe, we only run our radiators at night on the 2nd floor at bedtime for a few hours. I noticed a few nights ago that when I turned on the heat, the radiators did not warm AT ALL. So I spoke with a neighbor and he told me I had to bleed the lines. We do not have the kind with bleed screws, just turn a small valve. When I bleed the radiators not working nothing comes out. I decided to see if this was a whole-house thing, but found that when I turned on the first floor radiators they immediatly heated. What would cause a whole floor to stop working all of a sudden and how do I fix it?
14 Mar 2010
Norfolk
You tell us nothing about your system other than it doesn't work. To save having to read posts made 9 yrs ago, why not start anew?
D
Deleted2797112
Ditto for me! Found this thread googling for my half-cold radiator and did what paul the plumber suggested. Toasty-hot rad now. Thanks paul, even 9 years later!
19 Sep 2013
Yorkshire
try removing bleed screw and sticking a pin through..have come across ones that were blocked :rolleyes:
The pin worked for me. Phew and thanks! I had this exact problem and thought it was going to be a major ordeal to fix it. Previously, I'd tried a matchstick (thinking that a blockage might be the problem) but it didn't work. The pin was a good tip (literally!) - the matchstick was obviously too big.
31 Jan 2009
London
i had just had this problem & found that the problem was my header tank was empty - the float arm mustve been stuck so it hadn't refilled. seems fine now.
thanks to previous posters for all the advice.
s79
22 Nov 2007
Leicestershire
Hi. This is Paul, Im a plumber. This sounds very much like you have an air lock in the flow or return circuit pipes before this rad.
Solution. Close of all radiator valves on all radiators that are on that floor and run the heating as usual. After a while the rad will become hot. Bleed as usual then begin to open up the valves you closed on the other rads.
Good luck.
Hi all, in the above suggestion by Paul the Plumber, did Paul mean close "all" the rads on the floor or keep the valves open on the problem rad while running the system?
And also did he mean bleed while the system is running??
24 Oct 2018
Switzerland
This worked for me, I didn't know that the central heating system had to be pressurized manually. Upstairs radiator didn't bleed but I could hear it had air in it because of dripping sound inside the radiator.
There was a bar meter on the boiler, it was at 0.2 bars. It should be between 1 and 2 (my boiler seems to go up to 3).
I found the two taps that turned on the water inlet to the boiler, opened them, and BAZINGA! The water pressure immediately went up to 1.5 bar.
Now I could bleed the upstairs radiator. Also, had to readjust all radiators since water pressure is now higher. Had to increase pressure again after bleeding since it crept down below 1 bar again.
Super tip!
