if you turn off all the hot radiators, does the cold one then warm up?
if so, it is most likely because there is an easy passage of flow through the hot one(s).
If there is an easy path, them the hot water will tend all to go through there, especially if it is closest to the pump, it will circulate through the path of least resistance........
etc
etc
