Radiator on a twin entry valve
14 Mar 2021
I have to fix a radiator or towel rail radiator in a bathroom as the radiator is missing. The old connection has been left with only a twin entry valve.
Can I install a normal double radiator ( 40 cm width) by connecting one end with the Twin entry valve and cap off the other side of the radiator?
Is that possible to connect a towel rail radiator instead a normal radiator?
Or
Should I need a special radiator?
Please help me complete this job successfully.
Thank you
Dunsten
Nope you cant it is a dual entry valve needs a feed tube , best to just have a feed at either end
Thanks for that. Really appreciated. I will have the feed in one end and out connected to the other end.
