Radiator plastic transit plugs
15 May 2008
Devon
Hi, How do I remove the radiator plastic transit plugs from the two radiator tappings, so I can fit the bleeding air valve and blank end.
This is a new radiator.
Thanks Dave
Usually they'd just unscrew, but if you're having difficulties the only thing I can suggest is send them back, they shouldn"t be that tight!
Gurt screwdriver or pump pliers. Anticlockwise!
Surprisingly irritating as painted in.
Thank you, I gave them a tap with a hammer, seemed to do the job.
Thanks Dave :D :D :D
