Radiator sizing
7 Mar 2024
Hello,
I am going to replace some radiators in my flat. The current radiators are very old and sized pre-double glazing and loft extension, so I am questioning the sizes and numbers, especially as I am going to also replace the floor and I have flexibility with pipe sizing. Going round a few calculators online and I am getting wildly different numbers for the required BTU output.
I have so far used these
and I get the following BTU figures
RoomHeat adviserRadiators online
Lounge81025440
Study23011735
Spare room40492218
Hallway9642084
Kitchen46095679
I figured radiators online would be more reliable as it asks for more inputs (e.g. what's above/below the room), are there any other good ones out there?
We use Stelrad stars there are 2 versions one aimed at diy the better one you have to register for though still free.
You will probably need a understanding of how Hest loss calculations are done to get best out of it.
Wow that tool is amazing. I do have appreciation of heat losses, just what I needed. Thank you very much!
Quick question, the home page suggests:
Heat loss is presented in BTU (British Thermal Unit) and Watt. A figure of 20% is often added to all room heat loss calculations to fully comply with the requirements under BS 5449 concerning intermittent use of the system.
Does this mean the 20% is already built in or that I should build it in?
