Radiator Valve
3 Feb 2016
I recently moved into a new house and was looking into removing the radiator so I could paint behind it in the next few weeks when I start decorating. When looking at the valves, one end has a TRV and the other a different type. I closed the TRV and then went to close the other valve and found it was already 100% screwed clockwise already. When I turned it anti clockwise it started leaking from the connection, this leak stopped again when i turned it back clockwise 100%. I have tried tightening the nut on the connection but this made no difference.
The radiator heats ups when the TRV is open and has been in use the since we moved in without me knowing about the other valve. Is this dangerous to have one valve completely closed and could it cause problems for the rest of my central heating system?
I will obviously get this fixed when I remove the radiator for decorating but want to know if i need to have this radiator turned off the whole time until then?
cheers
