radiator valves
sim
18 Nov 2004
what is the difference between thermostatic rad valves and normal valves. both do the same job. can any one enlighten my .
Normal valves you manually open - close to try and get the right amount of water through them into the radiator to give you the radiator (room) temperature you require. Thermostatic valves allow you to set the temperature you require on each radiator via the 'tap' on the valve (normally graduated on a scale of 0 (cold) to 5 (hottest)). Then the valve automatically controls the flow of water into the radiator to achieve the temperature you have set.
