Radiators in one room not heating. Tried bleeding what next?
13 Apr 2011
Antrim
Two radiators in one of the rooms in the top floor won't heat up apart ftom very slightly at the bottom they actually will heat if we put the boiler up to 80 but the others all seem to heat at 65. Other radiators on same level you could cook an egg on. We tried bleeding. Any other ideas?
Sounds like poor flow. Do they have trv’s and do the pins operate? Lockshield valves open?
What are tvrs which pins and what are lock shield valves?
No idea what tvrs are, but trv’s are thermostatic radiator valves and lockshield valves are used to control the flow through the radiators. Pins sit under the trv’s, but tbh if you don’t know what these are or how to check them, then I’d say you’ve reached your limits and capabilities.
The thing to adjust radiator heat is called bulldog thet are turned to 5 and there is no heat from them that's all I know
If pins are not stuck on the problem rads then some balancing required.
May also be that rooms are at temp and trvs closing/closed?
Is the room to temp?
No it's pretty cold. This is out beside the boiler maybe it's not working
Free up pins.
Close lockshields down by 1/8th turn (at a time) on other very hot rads and see if this pushes heat to the cooler rads.
Leave it 10 mins between adjustments.
Free up pins.
I’ll leave you to make your own mind up @dilalio mate.
Turn off all the hot ones. All of them.
Do the cold ones now heat up?
