Right I have double checked a few things but can not find a obvious fault, however I am unsure about a couple of aspects.
- Firstly looked at the new thermostat and it appears to be wired correctly, but I don't understand whether the live to the thermostat should remain live even when the timer is off (I assume this is ok). Although I suspect that the wire from the thermostat (not the neutral) should not be constantly live even when the temperature is above thermostat setting. Any thoughts please?
- Secondly I tried to check the wiring at the junction where I connected the new valve wires to. It is difficult to tell but I am relatively happy everything is where it ought to be. However during my investigation I noticed that the cylinder thermostat switched on when I increased the temperature again despite the timer being in the off position. Could this indicate a fault with the timer? It was only replaced last year but that is probably irrelevant.
