Radiators not heating up
3 Feb 2010
Cheshire
Can anyone point me in the right direction. I've moved into a house which is costing me a fortune in gas and I can't get i warm. The central heating is an unvented system with a megaflow HE cylinder, valliant boiler and 22 rads. amoungst other things to try and sort it out I've had the system power flushed which has fixed the problems with se radiaors which I couldn't get anything out of but I still can't get the house warm, particulaly the rads farthest away from the bolier. I've tried to balance the system and now wonder if the pump is big enough but I don't want to go shelling out and a bigger pump doesn't solve the issue. Any advise would be appreciated
Maybe you have a bypass which is open too much??
where would a bypass like to be? The reason I ask is that the pump is in the boiler housing and when I was measuring the temperature difference between flow and return, I noticed what looked to be a bypass in there, only no valves to alter flow across it
