Radiators Single to Double upgrade...
18 Sep 2003
Hello experts
I want to know how difficult it would be to replace a single radiator to a double radiator- is it simply unbolt and unhook or something more involved... I need to know what the procedure is as I haven't done this before.
Oh and is www.screwfix.com a good place to buy rads from..?
OnlyAsking... said:
Hello experts
wouldnot know about screwfix sorry but
if the double rad is of exactly the same lenght and of exactly the same make then it is really easy :LOL:
if not it is a bit difficult
first measure it and go for the nearest size slightly shorter then get some extenders from the merchant for it, too make up the size.
the brackets for it sure be fitted as per instructions on the pack.
hope that helps and sure with this lot there will be loads more suggestions to follow.
I just been reading some DIY tips- whats this plastic piping stuff , can you use it for central heating- recommended? any feedback? :LOL:
Had a rad in last rented house moved, the plumber used plastic piping to extend from the original copper pipes
Use a slilghtly shorter replacement rad, telescopic connection extenders and you won't need to move any pipes or remove the valves.
no only asking you dont
if you ask for a DC slightly smaller than your existing one then do all the things already said
