Rain water under lead flashing leading to leak below
22 Nov 2026
Hi guys,
I bought a semi-detached dorma bungalow during the summer and now it’s winter, I’ve noticed a leak through the soffit boards above my back door when it rains. After a lot of investigation, I think I’ve found the problem! I pulled back the lead flashing on the side of the dorma and found that it was wet underneath and water was dripping off the bottom tile inside. I assume it’s collecting on top of the soffit board beneath and seeping through on the wall. Question is instead of getting a roofer out, what’s the best approach for me to tackle this myself. Any advice? Thanks
Not a roofer but I would think you need risers on top of each tile then fold the lead flashing down over them. If I am seeing your pics correctly.
If you are getting water into the soffits I would also check the felt is still hanging over into the gutters and hasn't torn off as old felt does.
