Hi all,
Just found this forum and thought someone might be able to help me before I call out a plumber.
Apologies in advance as im not too technical.
I have a Range Tribune HE boiler and the immersion has stopped working, looking at the instructions I think it has 2 immersion elements!
The boiler has 2 timers and 2 electric switches. The bottom switch and timer I leave permanently on and have this set to come on for 2 hours in the morning and 2 hours at night to heat the water. This is working fine as im still getting hot water.
However the top timer and switch which controls the immersion is no longer working as when I turn it on I dont get any hot water. I normally only use the immersion when we have run out of hot water and need some heating quickly.
This happened once before and I called out a plumber and he found the problem to be the fuse in the main electric box thing had tripped and he replaced this and it worked again.
I dont think this is the case this time however as I looked at the electric box and the switch had not tripped.
Anyone have any ideas as to what may have caused the immersion to stop working?
Many Thanks.
Many Thanks.
