rasied decking on paving slabs
11 Sep 2004
hi all, party of my raised deck will be over a single strip of paving slabs.
I need to put some posts down, but on the paving slabs do the posts just get attached to the joists and rest on the slab?
any advice?
hi put a runner on top of yor slabs ie3x2 or 4x2 then come off that with your 8x2 s or 6x2 s @ 90 degrees you might have to cut a joint out of your runners to fit onto the one on top of your slabs :) hope thats not as clear as mud :wink:
hi sorry i think i picked you up wrong yes rest your posts on top of your slabs or can be fixed with a plate and screwed onto slab :oops:
any advice?
yes they can do. its the easiest and quickets method providing the slabs are stable.
How is this done and what type of brackets do you use? Im about to do the same thing in a few months time!
If the base is tsable then the posts that the deck is supported on (assuming its at ground level) sit on the base. They do not need to be fixed to the base in anyway due to the weight of the deck.
....although the frame should be stopped fom travelling laterally by fixing it to something permanent, like the house.
