Hi all,
Got pilot on set controls to CH, boiler fires up for about 25 secs, then cuts out, pilot remains lit. Checked pump running on low speed then high speed ok. Overheat stat not cutting in, as pilot remains lit, checked high limit stat that has continuity ok. Boiler making a kettlying noise! when fired up, checked AAV to see that it was open one full turn, OK.
Must be some stat or something, as 2/3 mins later boiler fires up again for around 20-25 secs, then shuts down again, when CH in demand mode.
Could it be that the heat exchanger is blocked. Had the diverter valve changed around a month ago, as no DHW was forthcoming, but, had CH
Works fine in DHW Mode.
Any takers
Any takers
