My Ravenheat combi stopped working a fortnight ago. Using the fault finding guide I have attempted to diagnose and fix, but with no joy
The boiler does not work for HW or CH. I have changed the following in the same sequence; CH & HW sensors, main summer/winter switch, timer, main circuit board, low water pressure switch.
When switching boiler on the light on the front comes on. When selecting 'On' the timer relay clicks and testing continuity across terminals 3&5 it's ok. But still no voltage to pump and no movement of relays on main circuit?!
From reading through the fault finding flow chart in the boiler manual regardless of other faults the boiler pump should at least run?
I am wondering if the replacement circuit board could be faulty? It was an exchange board rather than brand new. But I'm sure it would have been tested.
