Ravenheat CSi85T
24 Apr 2007
Luton
I have the above boiler but the DHW is not getting very hot. The PHE was cleaned 2 months ago and the thermistors and poteniometers have been replaced. It was working fine untill 2 days ago.
I can see thru the sight glass that the gas only comes to full power when I unplug the DHW thermistor but it then goes on to get to hot and then cut out. I also note that if I press the screw end, which is concealed by the yellow cap on the gas valve, the gas appears to come to full power.
Any ideas what the problem might be?
Change the DHW thermistor seems faulty.
I Know you said it has been changed, but new parts can be faulty also.
STOP pressing the self destruction button...... you crazy guy.. :shock:
COuld be faulty gas valve or pcb (or something else!). Someone needs to measure mod coil voltages and gas pressures. Would probably be a corgi...
Might not be thinking clearly hear (been painting and drinking).
does'nt the thermistor modulate the gas by way of resistance?.
Whats the boiler doing on heating vinno?.
Sure, indirectly, but as the guy's changed it twice...??
It's the pcb which measures the resistance of the ntc, & decides what voltage to put on the mod coil. If say there's a HW control on the pcb with a broken track, gawd knows what you'd get.
Gas valve solenoid could be sticking I spose, though if it's been poked that might clear it!
Heating not on its DHW thats the prob. Poking the solenoid sounds like a plan. Any pointers wecome!
Thats my train of thought Chris, (points toward PCB emoticon)
Looked at my CSI manual(PDF) and cant read it, too blured.
