Morning, I'm looking for some advice please. We have a raven heat ls100t boiler, it's about 5 or 6 years old now, last year we had the divertor valve replaced. It has been working fine, it recently started making lots of noise, bangs and wheezes etc before cutting out. It have taken the cover off and can see a leak from the main large silver covered section, at the bottom of this section there are three holes with cables coming out of them, the one with a wire linking to the electronic bits has water dripping out, I have emptied as much of the system to avoid it leaking all day.
I will obviously not remove anything else I case it is dangerous, but do you think leaks in this area can be repaired? Or is it new boiler time?
We are in Manchester, if anybody can recommend an honest firm to use, i would appreciate it. Many thanks
