Ravenheat LS80T Cuts out
6 Nov 2003
Please help. I have a Ravenheat LS80T installed. When i turn on the hot water the burner fires up, then it stops after a few seconds and the flame failure light comes on. The same thing happens with the heating, the burner fires up, the pump runs, the electrode continues to spark with the burner lit, then the flame failure light comes on. I can reset it after a few seconds but the same thing happens time and time again. This is a new boiler. I would be grateful for any advice. Thank you.
I am not a plumber or heating engineer, but if as you say it is a new boiler why not call back the person who fitted it?
Thanks Breezer but I fitted it :oops:
I'll have to get a Corgi engineer to look I suppose, but I was hoping for some suggestions as to the cause of the problem so I can rectify it myself.
Oh dear well if your not a CORGI reg person you cannot have completed a BENCHMARK certificate in which case the best of luck getting any decent, qualified and competent engineer to work on it, not only that but any manufacturers guarantee is now also null and void.
This is why fitting a boiler is NOT a DIY job feel free to seek as much advise et etc as you can handle but please get a competent engineer to fit it.
as for the problem it is more than likely the flame recognition that is faulty so its going to be a new PCB, shame as this would have been a warrantee call
Boiler now working. I called a corgi registered engineer who switched the boiler on and it worked first time. No problems since. Is that sod's law.
The engineer didn't charge as he didn't have to do a thing.
Any problems in future and he'll be the one I call.
Thanks all.
