Rayburn nouvelle
22 Jan 2023
rayburn nouvelle does not fire up oil supply ok all cleaned no ignition fan working we are lost
A common problem with these is the pressure switch, but first make sure all the baffles are clear and loose in their slots.
Baffles clear central heating burner when ignored blows out cooler burner please help
You refer to the fan, so I assume you have the aspirated boiler burner with a glow plug and transformer. Are you saying that when the boiler comes on that the cooker burner goes off? If so, that would point to a fuel supply problem or a blocked flue, but that would then cause problems with fan proving and the pressure switch.
When was this last serviced ? I think you need to find someone who knows how these things work.
