We have a system thats been in a while and uses a Geldhill Boilermate II thermal store with an oil fired Rayburn Nouvelle.
My question is concerning the almost permanent running of the boiler pump. We only switch on the Rayburn boiler when we need instant hot water or central heating, othewise its off because it will just keep firing to heat the thermal store and waste an awful lot of oil. The problem is down to the setting of the thermal store dial on the front of the boilermate. If we have it set anywhere slightly above summer to winter, the neon light is always lit and the boiler pump continually runs. If we turn if right down to summer, it works as expected and the boiler pump cuts out after the 5 minute overrun. However given the Rayburn cooker is permanently on, there is always low background heating of water in the boiler pump circuit, enough to gradually heat the store for evening hot water and showers etc. The problem is that if the boiler pump is off, the hot water often gets to boiling point as it won't circulate well enough. The only way I've found of preventing this is to turn up the boilermate dial until the neon comes on, which then starts the pump. But its then running almost permanently.
Am I misunderstanding something we should be doing, or should there be somekind of additional thermostat to ensure the pump starts if the pipes in the Rayburn get to a certain temperature?
