Hi New to the site but been looking at a rayburn regent conversion to electric, we moved into our house and it had a oil converted rayburn (originally wood), we had great problems finding anyone who knew what they are doing to service it in the end found a oil boiler engineer who so called serviced it (think he only did a basic check on it) the rayburn would never get hot enough to be of much use other than heating the room a little, so clearly wasn't working correctly, so started looking at options,
1) convert back to wood - cheap to run but would need topping up etc and I'm out at work most the day,
2) keep trying to find someone that would service it and get it working,
3) try and convert to electric,
I then looked at the oil controller and saw how much oil it uses on min setting based at .67p per litre it would £3.85 per day on max £12.54 per day! so assuming low over night and high for a few hours cooking your going to pay about £6.00 per day.
So electric I wondered how much electric it would need to heat it up to the same temperature that the min setting was, so I drained out the oil in it and turned all that off, blocked up the chimney temporally with some foil and installed 2 low powered straight oven elements from a old £30 electric caravan type oven, and put these in the rayburn fire pit, the power being used is reading at 660-680w I left it to see if it got hot, after about 3-4 hours the top hot plate was reading 149 degrees c, (measured with infra red thermometer) and the oven using the door gauge was saying 100dc, while this isn't hot enough to cook on it was enough to heat the room up, cook toast, dry clothing and help keep the water warm,
So I feel thats a success, the next stage I've ordered a 1300w oven element (£3.50 on amazon) and going to try seeing how that works, my plan is to keep the 2 small elements in on 24/7 then use the larger element on a thermostat and switch to boost the heat when ready to cook just the same as you would turn the rayburn up when wanting to cook, I also have a 2.3kw element here and a oven fan that I may try to see what results I can get.
Of course if converting to electric must make sure there is a very good breaker and good earth on it,
any questions let me know,
