As I've been suggesting, I don't think they would be 'mistaken' if some of the cable between CU and RCD FCU were 'buried', would they?Also someone will say, mistakenly due to misreading the regulations, that he cannot have an RCD FCU without also having another RCD upstream in the consumer unit.
Not if it were new - but do you think existing wiring would require it because a new light or fan is fitted on the end.As I've been suggesting, I don't think they would be 'mistaken' if some of the cable between CU and RCD FCU were 'buried', would they?
Opinions seem to differ about that, and there doesn't seem to be any explicit guidance.Not if it were new - but do you think existing wiring would require it because a new light or fan is fitted on the end.
Quite so. One might as well afford 'currently required protection' to the entire circuit. The OP's idea of using an RCBO just for the new work because it would be marginally cheaper than an RCBO for his CU seems pretty trivial.I do not hold that view. ... Although, as seems to be the case here, if RCBOs are available for the existing CU, then one might as well fit one.
Dunno - as I said, some people seem to believe that changes/extensions to a circuit require the whole circuit to be brought into compliance with current regs, and I'm not sure that I would necessarily regard that view as 'wrong and silly'. As always, if the regs (or even 'guidelines') clarified this issue, there would be no need for debate or differing views.If that were not the case, it would surely be wrong and silly to say that an additional light cannot be fitted without replacing the CU.
That's obviously one view - but, as I said, there is no real clarity about this in the regs.If new work must conform to the latest regulations, and the regulations are not retrospective, then it stands to reason that the existing does not have to be updated.
That requires updating - RCDs have been required for most socket outlets for over 30 years.there are no RCDs at present, just MCBs.
Very true, in terms of current regulations - hence my earlier comments in this thread.That requires updating - RCDs have been required for most socket outlets for over 30 years. ...
Today almost everything requires RCDs, including cables in walls, all socket outlets, lighting circuits and various others.
Interesting - the second of those appears to be at variance with EFLI's view.If it was just replacing an existing item, such as a fan or light, then not required to update the circuit. ... If it's replacing something which manufacturer's instructions state that an RCD is required such as an electric shower, then the whole circuit is upgraded. ....
Do you mean RCD protection of the entire circuit, or just the new bits? If the former then, again, you view seems to differ from EFLI's.... Where wiring is added/altered and items are installed that didn't exist before, RCD is required.
Indeed - as you will be aware, I made that point at the very start.In the OPs case, what they are adding certainly requires RCD, and although adding a separate RCD is an option, it's rather pointless. Installing an RCBO for the whole circuit would be far better.
Some manufacturer's of showers correctly state that it is the circuit which requires the RCD; not the shower.If it's replacing something which manufacturer's instructions state that an RCD is required such as an electric shower, then the whole circuit is upgraded.
If the MIs say that, it's surely just a statement of what the current regs require, not anything to do with the requirements of their product, isn't it?Some manufacturer's of showers correctly state that it is the circuit which requires the RCD; not the shower.
