I've installed an RCD spur onto a downstairs ring which feeds an outside IP56 double socket. However, when using the test button on the RCD spur (intending to use it as an on/off), the main RCD in the CU trips out. Both RCD spur and CU RCD are contactum 30ma devices. Is this normal, or am I missing something.
edit: this happens when there is a load on the O/S socket (low voltage lights), but not when there is no load
