We have recently had a new split load consumer unit fitted, with a 30mA RCD. The kitchen sockets are on the RCD protected side of the board and we've been experiencing intermittant trips (maybe 2 - 3 times a week) when switching a fused switched spur (which feeds a socket under the worktop for the washing machine).
Curiously it only seems to happen when when using this switch and not if you leave the spur switched on and just switch the washing machine on and off... I've heard of appliances having a small amount of earth leakage, but it seemed a little odd that we don't get the trip when not using the switch??
This may be a stupid question, but is it possible for a faulty switch to be causing this trip (as seems the case)? If so is it best to replace the switch with a single or double pole switch? Double pole seems 'safer' and more robust, but I was wondering whether my choice could have an impact on the likelyhood of trips?
Also I was inteding to replace the switch with an unfused version (as there is already protection downstream) I assume this is acceptable?
Thanks in advance
Tryster
Thanks in advance
Tryster
