I think people are confusing the definitions we use for Earth Faults and Earth Leakage.
Thats interesting , this has tripped and stays tripped , cannot put the breaker back up , with this circuit connected.But arcing can cause RCD's to trip, specially the older ones, and I have had it where changing a plastic light switch stopped them tripping, and in theory there is no way a plastic switch can cause it.
Not true. When your socket was manufactured electric rechargeable toothbrushes did not exist. There is no reason your socket cannot be used with a toothbrush. Have you tried it?thanks for info on shaver socket, I will do very easy to get at the shaver , in fact i have been meaning to replace as when i specified I did not realise that tooth brushes could not be used in standard sockets , this one has shaver ONLY,so i can get one with a toothbrush symbol as well, so guests can recharge thier toothbrush, not sure about rechargeable shavers either.
No - Any idea why they have shaver only and shaver /toothbrush versionsThere is no reason your socket cannot be used with a toothbrush. Have you tried it?
It is said, shaver outlets are only rated for Intermittent use, whereas Toothbrush ones are rated for continuous useNo - Any idea why they have shaver only and shaver /toothbrush versions
The only difference is the label.
The one with shaver only is designed for intermittent use, and the one with shaver/tooth brush is designed for continuous use, in the main there is a switch that turns on the supply to transformer when the plug is inserted, some of the older units with shaver only if the transformer is continuously powered it gets too hot and discolours the plastic, even unplugging the lead from shaver rather than shaver socket can cause the over heating with the older type, as anything plugged in activates the supply to transformer.No - Any idea why they have shaver only and shaver /toothbrush versions
May be correct if you plug in the tooth brush to use, but that is rarely the case, there were some tooth pik things that were powered as used, but these used around 300 VA and the shaver outlet is rated 200 VA so the UK version had to be battery backed, so in real terms if it has the tooth brush mark it is continuously rated and with only shaver intermittent rated.The only difference is the label. As I said:
Yep, about to take the JB in loft to bitsBut seems your sorted anyway, fault large enough to show on multi-meter, I had it in daughters house, some one was not good stripping wire with a knife it seems, and had nicked the neutral, and the fixing screw for a socket touched it, took me around 3 hours to find showily getting closer to socket in question, most the time taken getting access to sockets.
Thats a good point, I'll just make any guests charge in bedroom thats not a problem , we have enough sockets in the spare bedrooms now they have been re-wired - good point - thnksif it has the tooth brush mark it is continuously rated and with only shaver intermittent rated.
Why shaver or tooth brush needs to be recharged in a bathroom
