Hi guys. I'm back again in search of more advice.
My project is going well.
I've done some of the wiring work on it and a spark has come and is happy.
The next stage is relating to lighting. Once I've got the advice here I'll one again consult a spark and have him check it over or help or what ever is needed.
I've done a epic MS paint diagram to show the current installation.
The thick orange vertical line represents a new wall. So now one large room has become two rooms. A pair of 2 way light switches for the two existing ceiling lights is depicted. The image describes the circuit and not the actual wiring path.
Switch X & Switch Z are both 2 way switches.
The Wall light (blue circle) is to be added.
As it's now two rooms; removing the 2 way system is probably better. Can I still use a 2 way light switch for a 1 way system though?
Ideally; Switch X will become a single; 1 way switch to operate ceiling light A.
Then; switch Z will remain a double switch with a 1 way circuit to operate Ceiling light B and the new wall light.
Is this sound thinking? Or am I overlooking something?
-Kane
PS. A question I meant to ask the spark before and forgot. Is it safe to encase twin and earth wiring for lighting and electrical sockets (separate circuits ofc) inside hardwood instead of the plaster/brickwork?
-Kane
